Removal of side reflectors to fit sissy bar plates
Old 02-13-2008, 01:52 PM
eagle56's Avatar
eagle56
eagle56 is offline
Default Removal of side reflectors to fit sissy bar plates
received my new sissy bar plates and rack for the new F/Boy.
Been trying to get the reflector of so i can fit the side plates but they will not budge.
can anyone tell meare they suck on with self adhesive tape.
Old 02-13-2008, 02:07 PM
jneubig's Avatar
jneubig
jneubig is offline
Default RE: Removal of side reflectors to fit sissy bar plates
They are put on with tape. Try a blow dryer to heat them up a bit, then use dental floss or fishing line to "slice" through the tape. It will leave some residue, but I used WD 40 to get that off. Hope this helps!
Old 02-13-2008, 02:29 PM
DMSC's Avatar
DMSC
DMSC is offline
I use something called Goof Off. I just use a small flat blade screw driver to gently pry the edge of the reflector up and squirt some under it. Let it sit for a few minutes and then grab the rflector and pull it off. You may have to squirt some more under the reflector.
The same stuff will remove the residue...
Old 02-13-2008, 02:54 PM
mke125125's Avatar
mke125125
mke125125 is offline
use the dental floss. pull it behind the reflector with a sawing motion. it will come right off. then soak the left over residue with "goo gone" from auto zone,it wont hurt the paint or chrome.I dont know if will damage black wrinkle or not. it will take a few soakings but with some elbow grease and patience it will be gone. also when rubbing the "goo"off use a microfiber towel so you dont scratch your paint.
Old 02-13-2008, 08:50 PM
Itsmedant's Avatar
Itsmedant
Itsmedant is offline
be carefull putting too much pressure on those reflectors, ive heard there is a chance of pushing in the metal behind it and causeing damage!
Old 02-13-2008, 11:27 PM
Waltman's Avatar
Waltman
Waltman is offline
The blow dryer is a good idea, and be patient, once it's warm enough start wiggling it. I used a flat screw driver. Whatever glue they use is a strong one, butthey will come off. I had mine parked outside on a sunny & hot summer day so it was easy to remove them. And make sure you cover the painted area with a towel before assembly.
Old 02-13-2008, 11:38 PM
imboden's Avatar
imboden
imboden is offline
just don't get the blow dryer too hot or you'll distort your reflector if you wanna re-use it. I took mine off and left em off.
Old 02-13-2008, 11:58 PM
Geoseismic's Avatar
Geoseismic
Geoseismic is offline
Reflectors - who needs reflectors? Put your new sissy bar on and don't worry about it.
TwoBlue02
06-14-2013 08:40 PM
goo
The General Motorcycle Forum
05-08-2013 08:45 AM
firefightermike
06-04-2012 07:57 PM
louisianaSVT2001
11-18-2010 01:13 PM
jtref
02-05-2009 08:00 PM
Quick Reply: Removal of side reflectors to fit sissy bar plates
