making bags detachable
RE: making bags detachable
I use barebacks on my Fatboy. Like them. Easy to get the bags on/off. Also got the covers for the studs when the bags are off. They look nice (chromed), but are plastic. For what they cost, I figured they should be metal. The only thing about using barebacks is that you cannot lock your bags to the bike. You can turn the studs that attach to the bags after you mount them so that the studs have to be turned to get the bags off (need a 9/16" wrench or socket). I am using a set with detachable sissybar.
Easy Brackets lock onto the bike when in use, and a simply turn of the key removes them so you don't have to leave them on.
They will mount to any stiff flat backed saddlebag. Install takes about 30 min. and no tools requiered when you put them on or take them off. Just a barrel key.
