Drag bar suggestions for short guys..
Im 5'8" and i have harley drag bars w/ the 6 1/2" straight risers and they just pull me to far forward on the bike, in result a sore back after i take a ride, i was wondering what some of you guys are using for drag bars, and hopefully straighten out my back some when i ride
RE: Drag bar suggestions for short guys..
I'm 5'6" and I just put a set of White Brothers Burly Super-Riser Medium Drag Bars on. Here are the specs:
Center Width: 8 in.
Description: Dimpled and Pre-Drilled
End Rise: 8 1/4 in.
Pullback: 6 in.
Rise: 9 in.
They fit me perfectly. I had a slight bend in my elbows with the stock Fatty bars, but with these drag bars my arms are straight but I don't have to lean forward. For my Fatty, I had to get the fattest bars I could, that being 1 1/2". They look sweet. When I was looking, I went to an indy shop and I told them what I wanted, number on being the weld area smooth prior to chroming. I was told that I would have to get Carlini's for that and they were very $$$$$. The White brothers have that weld area smooth and it was exactly what I wanted. I got them at Dennis Kirk for $217.99 plus shipping. Well worth the coin.
Center Width: 8 in.
End Rise: 8 1/4 in.
Pullback: 6 in.
Rise: 9 in.
You might want to check into the Baron's Big Radius bars. They are fat, have smooth welds, and the top bar is more of a gentle curveshape instead ofa straight bar with a sharp bend at each end.I'm an ape hanger guy myself, but if I had to go back to drag bars I would go back to the Big Radius.
check out these bars from carlini. the link is below. i have the carlini sweep bars and they are worth the $$$.
http://www.carlinidesign.com/handleb...ersweep125.php
I'm 5'6". I had Carlini bars on my Deuce, and they were great for shorter rides. When I'd do longer rides, they'd start to hurt my back a little. I wound up trading my Deuce for the Softail Custom I have now. I have 12.5" apes now, and I have yet to have my back start to hurt. Drag bars look really good, but they're not always comfortable. Apes look good and are really comfortable as long as you don't go too high. Shoulder height is perfect.
