help with parts to fit 2006 FXSTi with 200mm rear tire
G'day all,
Wondering if any of you can help re. this. Friend has a 2006 Softail Standard (FXSTi) Fuel Injectedwith 200mm rear tire. So because it has a 200mm rear tire we are not sure if the parts to go on it are the ones that usually go on the 07/08 models for most other bikes OR the traditional 86-06 fitment.
Need to know if this bike fits:
26029 big radius OR 26003 big radius
805-511 Power commander OR 803-511 Power commander
Am pretty sure that the 18-507 Arlen Ness Big Sucker will fit this. If someone could please advise so we order the right bits.
Thanks in advance,
DeanO
Thanks in advance,
DeanO
RE: help with parts to fit 2006 FXSTi with 200mm rear tire
You'll need the V&H Big radius 26003, and the PCIII 805-511. The difference between the two exhaust is that the one your looking for does not have the O2 sensor bungs and the 07/08 need them.. and the PCIII is the 813-511 is for the 07/08 models and for the same reason 02 sensor elliminators..
Hope this helps.
Hope this helps.
