Struts on a 07 deuce
i was wondering if anyone has changed the rear fender out themselfs i purchased a wider fender for a 200 tire and it comes with new struts. The deuce has about ten inches of strut coming off the back of the frame that is basicly in the way of mounting the new struts. So do i just lopp those things off or just go a whole other route and probably end upcosting a whole lot more then i intended on spending.
RE: Struts on a 07 deuce
Can you provide some more info on the kit you bought? What is it? Does it have any instructions guiding you on the strut install? You can't use the stock struts? etc...
Without more info my guess would be that you would have to chop the stock struts and weld the new ones on in place of the originals. Harley never anticipated anyone throwing more than a 180 between the stock struts. Plus, your kit came with sturts so that's an indication a swap is required.
sorry, i bought the fender from mc avantages
Rear Fender, Flat, Struts For Softail®, 9"
Part STXF035[/align]By Stampedeâ„¢[/align]Raw Struts, Fender/Strut Kit[/align][/align]Thanks for the help I was thinking that was the only way is to remove the struts on my bike frame but i wasnt sure if that would ruin the strengh of the frame, doesnt look like it would but you never know and i sure dont! I will try to upload some pics later on so you will have a better idea![/align]
Ok, got it now. Yeah, you would have to cut the OEM struts off. Looks like that kit just bolts up by the seat.
As far as whether or not the new fender and strut assembly will support a passenger and/or baggage, I'd contact the company. Just from the look I'd say no. This looks like it would make it a full-time solo ride.
