Will it really be a noticeable power difference??
Old 02-22-2008, 05:01 PM
Road Chick1's Avatar
Road Chick1
Road Chick1 is offline
Default Will it really be a noticeable power difference??
I just had Vance and Hines Softail Duals installed on my Softail Deluxe, and I am not impressed with the power. I also had the bike dyno tuned, Big Ness Air Kit, and a FuelPak installed.
Would the Big Shots Staggereds give me a noticable power increase, or how about the Big Radius Two into One???
http://i16.photobucket.com/albums/b2...Feb2008004.jpg
http://i16.photobucket.com/albums/b2...Feb2008003.jpg
Old 02-22-2008, 05:33 PM
85FXWG's Avatar
85FXWG
85FXWG is offline
Default RE: Will it really be a noticeable power difference??
Sorry to tell ya, it doesn't matter what pipes you put on it , you aren't going to gain very much HP. You need some high performance cams, bigger pistons and stroketo really gain some HP.[/align]
ORIGINAL: Road Chick1
Old 02-22-2008, 05:42 PM
Five0's Avatar
Five0
Five0 is offline
I recently installed a set of V&H BS longs on my 08 Softie along with a Fuelpak andstage 1 AC. NO dyno, just a little tweekin on the Fuelpak with help from V&H. Made BIGGGG Difference on mine. Lots more low end!
Old 02-22-2008, 05:44 PM
cskyler22's Avatar
cskyler22
cskyler22 is offline
That is true, you wont see much gains. Also are you sure you got the Dyna Tune. If you got it from you local HD shop, they probably just did a Dyna map, which is getting a predone map and uploading into the PCIII. They usually charge about an extra $100 (of course HD!!! hundred dollars) to actually sit down and TUNE it to the specific bike, pipes ect......
[IMG]local://upfiles/52233/639F9D91E6A248389F37C3E695BEE57E.jpg[/IMG]
Old 02-22-2008, 05:50 PM
Herr Monk's Avatar
Herr Monk
Herr Monk is offline
You will get more power out of a 2>1 than a 2-2.
But a tuning, and stage I will only get your engine running to its current potential, it's still a low-rev, air-cooled, push-rod, counterbalanced engine. It's going to take allot of $$$ make it fast...
With a stage I you can expect, best case mid 80s for tq and high 70s for hp...
A 650+ilb bike won't even start to be "fast" 'till you break the 100hp(not tq) mark... and that will require some work
Old 02-22-2008, 06:04 PM
firemankrug's Avatar
firemankrug
firemankrug is offline
ORIGINAL: Herr Monk
Yup, My dyno results after V&H Big Shot Longs, SE A/C, SERT was HP=72.9 TQ=86.8
I did notice a big difference in sound and a small difference in performance.
Old 02-22-2008, 07:55 PM
05 HD Deluxe's Avatar
05 HD Deluxe
05 HD Deluxe is offline
You mention you had a fuel pak and hadit dyno tuned. Does your dealer or indy know how to adjust the fuel pak ? If not you paid for a dyno dune for nothing. Basicly the fuel pak is supposed to be plug & play. What were your numbers on the dyno ? HP & TQ
Old 02-22-2008, 09:47 PM
BoneCrusher's Avatar
BoneCrusher
BoneCrusher is offline
I agree with most of the comments here, changing pipes on that setup isn't going to give you any noticeable power gains. When I went from stock to stage one I noticed a lot more sound but not a real noticeable seat of the pants increase in power like fireman said.
Old 02-22-2008, 09:53 PM
Road Chick1
Thanks for the feedback. Yes, I did get the dyno tune. I had all this work done at Cycle Visions an Indy in San Diego, good outfit.
I did notice some change in performance, but my question really is this:
Will I notice more change if I go to a different pipe??
For example the big radiius two into one?
Old 02-22-2008, 10:04 PM
cskyler22's Avatar
cskyler22
No, your not going to get much difference, maybe a little but won't give you a drastic change... By the way, nice bike, nice color choice!!!!!!! Almost looks like mine!! lol
Quick Reply: Will it really be a noticeable power difference??
