Help for newbie
Help for newbie
Hello, picking up a very nice 2006 Softail standard on Monday, Im looking to change the Primary,Cam and transmission covers to chrome.
Can anyone give me any tips on changing the covers, never worked on a Harley before asIvehad mainly Triumphs
Secondly I dont like the softail bobber rear fender much....is it possible to fit a Fatboy style fender without too many problems.
Many thanks in advance Ed
RE: Help for newbie
These changes are rather straight forward, I've been lucky and was able to reuse the gaskets, the primary gasket itself at the stealership is $45.00. Also look at the Hot Toppers for your bolts, they work real good. Somewhere on here is a picture where a fella put a Fatboy rear finder on a standard, but I'll let you find that one, might be in the standard pictures.
[IMG]local://upfiles/49112/955A064F6962480EB44F5561D80F257C.jpg[/IMG]
RE: Help for newbie
Brown's Plating does real good work, and they have a chrome exchange program to limit the downtime. Here is the link: http://www.brownsplating.com/index.php
RE: Help for newbie
Can't answer your question on swapping out the rear fender, nor tell you what "hot bobbers", but switching out all the covers for chrome ones is a breeze. Make sure you get the right size Torx head for the job. (#27, if I recall...been a while...) As mentioned, if you're careful you can reuse gaskets, etc. Took me under and hour to swap them all out on my Fat Boy. Good luck with it.
