turn signal relocation Deuce
RE: turn signal relocation Deuce
The HD catalog has a turn signal relocation kitfor theDeuce that looks real clean, no clamps around the forks.
I installed it on my "old" '06 Deuce.
you will either need to raise the gas tank to get to the turn signal connectors or cut the wires and resolder them back together.
You dont need to cut the wires....the pins can be removed from the harness with a pin removal tool and if you dont have that use an awl or something pointed. Make sure you write down which pin goes where. I had enough play where i didnt need to remove my tank, just make sure you have towels around to protect your paint and chrome
ORIGINAL: Deuce Bigelow
