Will the fender rack still fit?
RE: Will the fender rack still fit?
Yes it will, got that setup myself.
You just need to get the adaptor listed as PN = 59320-07 for it.
The rack install with the stock tailight needs to have two holes drilled into the tailight housing, a bit of a pain to do. But because of the plastic housingits not rated for a lot of weight, about 10lbs. But putting the adaptor on changes the rear mounting points to a sizable piece of steel plate and even though there are no published rating changes. Its a sure bet it can support at least 20/30 pounds more weight.
