Shift Lever centering spring????
RE: Shift Lever centering spring????
If your thinking of replacing it cause the shifter sticks on you. I suggest you first try disconnecting the shift linkage and seeing if the pedals are just sticking on the pivot bolt. Its a very common ailment on the later Softails and easy to fix.
If it is just the pivot bolt, just pull it out, clean it up, and relube it with a good grade of grease or anti-sieze. Put the shift linkage back on and you'll be back in business.
Shouldn't take you more than 20/30 minutes if the bolt comes out without a fight.
