PC111
Old 03-03-2008, 09:04 AM
FIST_FULL's Avatar
FIST_FULL
FIST_FULL is offline
Default PC111
So i installed my new pc111 on my 2007 harley...installed it with directions with unit to the "T". Know the bike is not starting...starter clicks as if it wants to start. So my biggest question is if the battery is completely dead how long does a full charge take?
ssls6's Avatar
ssls6
ssls6 is offline
Default RE: PC111
Loose battery cable?
Old 03-03-2008, 09:13 AM
FIST_FULL's Avatar
FIST_FULL
Default RE: PC111
Checked both neg. and pos. both tight.
The one concern i have is that they set this up in such a small place. you have to bend the harness in half.
Old 03-03-2008, 12:45 PM
Waltman's Avatar
Waltman
Waltman is offline
Default RE: PC111
I just installed my PCIII this weekend also, and the bike runs sweet. Yes the space in there is tight, just push everything down, the cables won't brake. Check if you plugged the connectors in the PCIII correctly. In my FB there are3 cables that connect to the + and 2 to the - side of the battery. Did you forget to connectthe fuse box cover?That's where thesecurity systemis connected.
Old 03-04-2008, 05:34 AM
Road_Clam's Avatar
Road_Clam
Road_Clam is offline
Default RE: PC111
ORIGINAL: FIST_FULL
About 10-15 hours at 1.5 amps output (a typical M/Ctrickle charger's output)
Get a Battery Tender, they are the berries. They have a simple charge progress light: Solid red means charging, flashing green means the battery is 80% charged, and solid green means fully charged......
Old 03-04-2008, 05:50 AM
T_Rob666's Avatar
T_Rob666
T_Rob666 is offline
Default RE: PC111
ORIGINAL: FIST_FULL
Question: Was the battery dead before you installed the PCIII? When was the last time you started it up?
Old 03-04-2008, 09:49 AM
FIST_FULL's Avatar
FIST_FULL
Default RE: PC111
I keep kicking myself in the a$$...Never tried to start it before i started the job.
manchez
06-14-2017 01:13 PM
Moondogger
04-20-2013 07:38 PM
EvilWayz
Ironhead
21
03-12-2011 03:44 PM
cavalier2000
11-15-2010 05:26 AM
TDSnowSPR
07-10-2010 10:29 PM
Quick Reply: PC111
