Low cost lowering shocks ?
RE: Low cost lowering shocks ?
Never seen those. I'd be leary.
There are basically two preferred (inexpensive) methods for lowering. One is a kit similar to the Burnout Cycles kit. J&P Cycles has one similar. These will run you about $100. The up side is they use the stock shocks and don't require disassembly of the shock.
The other is a kit that provides you longer shock post bolts. There are many variations of these floating around and they all do the same thing. However, prices vary from as low as $15 to as much as $200 depending on brand names. Like the other kit, these use the stock shocks. Different from the other kits, these will require disassembly of the shock to install the bolts. This can run about $25-40 labor depending on your location. You can do it yourself if you have the means to compress the shocks. A few of the more expensive variations of these kits will include a kickstand. Those are the only ones that give any indication they are worth more than the less expensive cousins. I used a $15 kit on one of my bikes. It installed fine and despite lowering a good 2+", did not require a new kickstand. I can't see any extra value in spending more than 10X that for a kit from Ness. Bolts are bolts. But results will vary I'm sure.
For most, these kits offer the best bang for the buck, even if you went with the Ness slam kit which appears to be one of the most overpriced of them all. As long as you are content with the ride of the stock shocks, these will lower your bike on a budget. If you are not happy with the stock shocks performance, these kits will not make it any better. If anything, reports are that it can make the ride a bit more harsh. Several factors contribute to that: roads surfaces you ride on, weight of the rider, 2-up versus 1-up, how low you go and what preload you set on the shocks.
If you don't like the stock shocks, you are better off going with an aftermarket shock that gives you a better ride over stock and offers the ability to lower your bike, such as Progressive shocks. And if your wallet is bottomless you could look into an air ride shock solution.
Hope that helps.
Hope that helps.
I agree you get what you pay for, but I have a daytec softail frame and the typical 99 and older softail shocks wont fit, only "works" narrow body shocks. Was hoping someone had these installed and could give some feedback on if they are junk or not, I expect they are import's?
Thanks!
Thanks!
ORIGINAL: bensonjv
what type/brand did you use that only cost 15/20 dollars I have considered dropping my bike several times only don't like the idea of having to take the shock apart. any info appreciated....
Hope that helps.
Hope that helps.
