HELP!!!! with rear brake line and Arlen Ness 3" Extensions
I have spent enough money this year at the stealership so I decided to install Arlen Ness 3" extensions myself and I am no wrench. Shifter side no problem, then I get to the brake side and the directions tell me to reference my service manual which I do; however, there is no friggin detail on the removal of the rear brake line and I know brake fluid will eat through anything. Can anyone help me out with this or does anyone have a schematic I can reference?
Thank for your help.
****UPDATE**** It took at few hours and some switching back and forth; however, she is done, just need to bleed the brakes. Thanks for your help. Thank god for this site.
RE: HELP!!!! with rear brake line and Arlen Ness 3" Extensions
ORIGINAL: vertigo14
undo one side while a rag is wrapped around it to protect from spills.. put a drain pan under the line and drain out then u can remove the otherside and .. take it off..
Did these myself to, like the boys said when you undo each end just wrap with a rag so you dont drip any fluid, if you spill any on paint work dont wipe off, just get a cup of water on standby and pour it over the effected spot.
One problem I had was the flat washer that came with the Ness kit would not seal. Put 2 new stock washers on problem gone. Disconnect the caliper line at the switch manifold and let it drain and you shouldn't have much fluid left in the rear line. A Mini Vac will make bleeding a snap and for 29.00$ is a handy tool to have in your box.
ORIGINAL: back again
