New pipes on '07 Softail
RE: New pipes on '07 Softail
Think you have it backwards, most guys have and really like the PCIII. It may or may not be all that much better but it isa lot easier to find maps for. Its also easier to get dyno tuned as many dyno's are setup toaccess it directly and can update the map's on the fly as it were.
If your looking for the "Best" fuel managment system, add-ons won't do. For that you have to basically junk the original ECM and use a complete replacement system like the TMax w/Autotune, or the Daytona Twin Tech system.
I have an 07 Deluxe. I put V&H Bigshot longs and used the fuel pak. You will need to do somthing to re-tune your ECM.
Most guys here do have the PCIII. As far as finding the map for you bike if you do go with the fuel pack, just go to Vanceandhines.com and they have a link to their fuel pak web site. From there you can get the map you need.
From the tech sections (https://www.hdforums.com/forumid_247/tt.htm):-
Tuning EFI bikes https://www.hdforums.com/m_341723/tm.htm
SERT, PC III, TFI or DFO? https://www.hdforums.com/m_228829/tm.htm
MARCUS 79
01-14-2009 08:12 PM
