TURN SIGNAL RELOCATION 101 (with pics)
#31
#32
I did this mod a couple of years ago. I put anti seize on the stud that goes into the triple tree and did not use locktite, everything is holding tight after 3 years. I got my studs and nuts at Grainger, Fastenal has them too.
You cannot put a spacer over the two nuts because you have to install the nuts onto the stud then install the turnsignal. You won't be abe to tighten the nuts up to the t/s and the triple tree. You can install the windshield bushings on the same post if you want you nee a 1/4" longer stud. The t/s sticks out a little further but it doesn't look too bad especially if you want to use your windshield.
Mine's a 2001 so I replaced the older style turnsignals with the newer deuce style signals.
I also moved the rear t/s to mount on the License plate bracket with th Bubba's Brakes part.
#34
#36
#37
blacksportster05
01-18-2014 01:36 PM
