LQQK What I Found EZ-FILL :):):)
Look What I Found, No More Removeing Derby Cover To Fill Or Check Oil In Your Primary By Corbin EZfill
http://www.corbin.com/accessories/ezpour.shtml
It's one of those things that is so simple it makes you want to scream... "Why hasn't this been done before?" With the Corbin EZ-Fill adding oil to your primary is simple, just remove the knurled plug from the inspection cover and pour. It looks great and works just as well (a hallmark of Corbin design).
Forged aluminum and triple plate chromed for a perfect fit and finish. Rubber o-ring creates a positive seal and secure fit of the chromed plug. Two models are available for a variety of Harley-Davidson models.
#HD-ST-EZ-FILL
Fits: 1970 - 2006
FX, FL Shovelheads
FLST Softails
FXDWG Dyna Wide-Glide
Softail Deuce
#HD-FLH-EZ-FILL
Fits: 1985 - 2006
FXR Models
Roadking
Road-Glide
FLH / FLT models
Special Notes and Info
EZ-Fill primary inspection covers do not fit on Harley models with mid-controls like the standard Dyna-Glides. There is no hole for the shifter shaft.
On some models, it may be required to slightly bend the side-stand helper for clearance (that's the thing you hook your boot on to get the stand to swing out).
EZ-Fill primary inspection covers do not fit the 2007 models.
EZ-Fill primary inspection covers do not fit any after market shifters that are longer than stock shifters.
ITEM
DESCRIPTION
PRICE
#HD-ST-EZ-FILL
EZ-Fill Cover, Shovelhead, Softails, Deuce & Dyna Wide-Glide
$99.00
#HD-FLH-EZ-FILL
EZ-Fill Cover, FLH/FLT, Roadking, Roadglide & FXR
$99.00[/align]
#HD-ST-EZ-FILL
Fits: 1970 - 2006
FX, FL Shovelheads
FLST Softails
Softail Deuce
#HD-FLH-EZ-FILL
Fits: 1985 - 2006
FXR Models
Roadking
Road-Glide
FLH / FLT models
ITEM
DESCRIPTION
PRICE
#HD-ST-EZ-FILL
$99.00
#HD-FLH-EZ-FILL
$99.00[/align]
RE: LQQK What I Found EZ-FILL :):):)
Well You Read The Owners Manual , For The Right Amount Of Oil Drain It And Replace The Right Amount In The EZ Fill Hole And Ride On Your Done, Without The EZ Fill Plug The Derby Cover Has To Come Off To Refill It, And It Just Fills Up To The Bottom Of The Clutch Pack And Bike Has To Be Level
With The EZ Fill Plug It A Hole Lot Easer,
Remember Read Your Owners Book For Primary Oil Amount
Enjoy Your Ride
Enjoy Your Ride
check, corbin, cover, covers, ez, ezfill, fill, found, foundez, glide, hdflhezfill, hdstezfill, inspection, plug, wide
