Front Master Cylinder Leak
Thought I fixed this, but still getting some brake fluid leaking around one of the screws. I replaced the gasket and torqued it down good. I was careful not to pinch the gasket or tighten too much.
Any suggestions?
This didn't start until last week when I removed my master cylinder to pull the wires out of my bars. I turn the master cylinder up side down for several minutes. I have replaced the gasket since then
Any suggestions?
RE: Front Master Cylinder Leak
Got it figured out. It wasn't actually leaking after I replaced the gasket. There was residual brake fluid up under the lip of the gasket that was running down the outside of the master cylinder. I took a tiny flat head screw driver wrapped in painters tape (so not to tear the gasket or scratch the master cylinder) and pushed a piece of cloth up under the lip of the gasket and dried all the residual brake fluid up. All is dry now.
