Deuce Brawler seat mount with filler panel?
Hi guys,
This very well may be a very stupid question but here it goes anyway.... How do you mound a solo seat on a deuce? Im looking at the harley brawler solo seat the filler panel specifically but any solo seat?? If you guys have any close up pics of one mounted or the mounting locations would really help.
Thanks!
joe
Thanks!
joe
RE: Deuce Brawler seat mount with filler panel?
So, is this something thats easy to switch out quickly. What im trying to do is run this solo seat/ filler panel combo when Im alone and put on the Corbin Gunfighter and lady with the built in passenger backrest when the wife is along (this seat requires no sissy bar mounting plate)
Thanks for the quick reply!
Joe
Joe
It will take you about 5 minutes to make the switch, and that's taking your time. Remove your 2-up seat, put the filler panel on first. As stated above, it lines up with the hole in your fender where the back of the 2-up seat bolts in. Then remove the front strut bolt on each side (right above your passenger pegs), and loosen the bolt just behind it on both sides (just to give the strut a little wiggle room when you install the solo seat), put on the solo seat, reinstall the front bolt on each side and tighten them all down. Your good to go.
