05' Deluxe vs 07' Deluxe frame ?
Going to change stock seat with a spring vintage solo. Looking around, most of the kits are for hardware (ie., springs, mounts, clips, etc), but don't provide covers for the battery and ECM. I think I found a seat frame mount cover, took some ballpark measurements, and looks like it should fit. The description is for 2000-2005 Harley FXST-FLST .
If anyone has knowledge if the 05' and 07'frames are pretty much the same OR if you have an 05' and could take 3 measurements, I'll match it up with my 07'.
1. top, where the pic indicates 7.25"
2. middle, where pic indicates 11.5"
3. seat neck, where pic indicates 5.75"
any other inputs or opinions are greatly appreciated..
[IMG]local://upfiles/34488/771FF964372F4E96A47D28E93828BDE7.gif[/IMG]
RE: 05' Deluxe vs 07' Deluxe frame ?
It is kind of difficult to understand what you are asking for in that photo. I can tell you that at the front of the seat area itis "about" 4" wide on my '05. At the bolt point (where the bolts go through the seat base and mount to the frame) it is about 11.5" and the ECM area is about 5.5" wide. I hope this helps. Let me know. By the way, I only measured once and have a terrible cold so there may be errors.
I don't think there are any differences in frames between years.
Mark
Mark
Hey Mark,
Yeah, I'm just trying to match up my measurements to the 05'. Just trying to get the 3 main points of the cover.
But, your just the guy I should be talking to. Did you do put the seat on yourself? Tell me about it..
[ol][*]where did you get seat, and any complaints?[*]did you use a seat frame cover for battery and ecm?[*]what did you use for kit?[*]how much did it raise from stock? I could use a liitle height extension, even at 5'7.[/ol]
And your pipes?
[ol][*]true duals or crossover? I was thinking V&H or Rinehart without fishtails.[*]any complaints?[/ol]
And your pipes?
ORIGINAL: ronyd
Hey Mark,
And your pipes?
Hey Mark,
And your pipes?
It does raise you up a bit. Where I am used to sitting into the frame I am now up quite a bit. It is a totally different feel. I am only 5'6" tall and can still touch with both feet with only slight tip toeing.
I am running Samson True Duals and like them although I think they could have designed the shift rod better as it wants to rub the primary or heat shield.I like the sound though.
Mark
Mark,
Yeah I think the seat frame cover I show along with the kit (31-4190) should do the trick. V-Twin Mfg. are the sole supplier's. There's http://www.debrix.comwho is a distributor at 15% discount. Was the seat base any of the others on page 1182 of Vtwin catalog http://www.vtwinmfg.com/Catalog1/VTwinCatalogIndex1.htm?
ORIGINAL: ronyd
thankx Mark, and the seat base you used was on which page?
Mark
sorry Mike, bear with me here. Need to rewind back to what you described. Looking at the kit, I see the T-Bar, but what is the Base you are talking about. And doesn;t a complete seat consist of a seat pan and covering. Sorry don;t understand what you modified, seat base or seat pan?
When looking at the photo of the kit in the upper left is a black painted piece that goes across the frame and bolts into the frame at the widest point. It also has two screws that go into the area right behind the fuse panel. In order to make it work without relocating the ECM I ground away an area to allow the wiring to pass around it. This piece is what the springs attach to from the bottom. I also had to make a few other adjustments.
A seat is a seat pan and a covering. This will attach to the T-Bar. As for a frame cover, I believe their part number 42-0942 is the one you want but since I did not use their part you will need to confirm.
MARK
MARK
