Detachable passenger backrest and saddlebags
RE: Detachable passenger backrest and saddlebags
ORIGINAL: Arvis
Hi Guys,
what kind of saddlebag supports would you recommend that would go with detachable passenger backrest.
Backrest goes with special mounts. You cannot put anything between them and struts (because backrest would not fit anymore).
Hi Guys,
http://www.easybrackets.com/products...n.htm#Softails
I modded the easy brackets to bolt up to my HD rigid saddlebags. You can purchase a set of Easy Bracket mounts that are designed to work with the stock HD detatchable backrest. So now I have detatchable saddlebags, and a detatchable backrest. Heres a link with pics asto how I did it:
https://www.hdforums.com/m_1763891/tm.htm
Check out Bubba's quick release system. A little pricy, but quality stuff.
http://www.bubbasbrake.com/xcart/home.php
ORIGINAL: mikef
Do any of you guys ever actually remove them?
I don't like the "bird watcher" look of saddlebags . However, when I commute to work, bags are aGREAT way to carry my lunch, and some extra cold weather gear if needed.....
Struts for Detachable Backrest & Saddlebags
I got crafty and used a set of Easy Brackets :
leeinmemphis
05-14-2016 11:33 PM
jakester
03-13-2008 06:11 PM
