How Do I....
Old 03-30-2008, 11:15 AM
chunderboy's Avatar
chunderboy
chunderboy is offline
Default How Do I....
Relocate my blinkers from the stock location to underneath the auxiliary light bar? I just put on some 18 in apes, and I like the look of the blinkers underneath the auxiliary lights. And I havea 1995 fb.
Old 03-30-2008, 12:26 PM
JoeFLHX's Avatar
JoeFLHX
JoeFLHX is offline
Default RE: How Do I....
HD sells a kits to do that.
Old 03-30-2008, 12:48 PM
chunderboy's Avatar
chunderboy
How much do they bang you out for that one? I was hoping someone had a diff. company that makes it. Oh well, just gotta do a little research. Thanks for your help
Old 03-30-2008, 10:01 PM
gunner065's Avatar
gunner065
gunner065 is offline
I got a 5/16' 24 SS bolt and cut the head off. I then threaded the bolt into the lower screw hole on the front tins using blue loctight. You then can screw the signal light onto the bolt, again using blue loctight. I picked up a couple of chrome spacers from the dealership that goes between the tins and signal light to hide the stud. A few people have used SS nuts to keep everything in place, but then you see the nuts. I prefer the spacers myself. The blue loctight works good and they haven't come loose yet. Knock on wood.
Old 03-31-2008, 08:03 AM
chunderboy's Avatar
chunderboy
gunner065,
You wouldn't have any close-ups of your signals, would you? If you could it would be much easier for me to see what you did.
Thanks again bro
Old 03-31-2008, 08:09 AM
Fairmont FatBoy's Avatar
Fairmont FatBoy
Fairmont FatBoy is offline
I am in the process of doing the same thing. I put on 16" apes yesterday. I wont to relocate to undernieth my tri-bar. I dont wont to pay the HD rate so if there is an aftermarket brand that will work that would be great.
Old 03-31-2008, 08:39 AM
chunderboy's Avatar
chunderboy
Fairmont FatBoy,
That is pretty much the same reason I started this post. HD sells isht that cost too much for what it is (sometimes). I wonder if there are ever any tech meeting for guys in the tri-state to help other noobs like me make some minor changes on the scoots.
Old 03-31-2008, 08:54 AM
hspring03's Avatar
hspring03
hspring03 is offline
I moved mine from the bars
To under the spots.
I used an HD turn signal kit....I'll try to find the part. You did say you have the aux bar, right?
Old 03-31-2008, 08:58 AM
chunderboy's Avatar
chunderboy
hspring03
You've got it, I have pretty much the same aux light set-up as you. How tall are those ape's, I just put on 18's?
Old 03-31-2008, 09:00 AM
hspring03's Avatar
hspring03
This is the one
http://www.harley-davidson.com/gma/g...bmLocale=en_US
Those are 16's
Quick Reply: How Do I....
