Changing paint set
RE: Changing paint set
Mine's an 03 but the plug was under the seat for the rear lights. I unpluged it and then removed the bolts that hold the fender struts and fender to the frame supports and then took the others that hold the fender strut to the fender off on a bench. I did all that and removed my oil tank without removing the rear tire.
I just changed out the rear fender on my 02 Heritage Springer... Didn't have to take the tire off...You will have to jack it up to get at the bolts...And the post above me is correct. Take off the seat. Taillight and directionals are plugged into the harness. With a small pic you should be able to lift out the pins to re-use the wiring.
