Harley Download or ???
I did the Harely Download as soon as I had my Vance & Hines Big Radius Pipes installed and the Screaming Eagle High Flow Air Intake. I am not completely happy with the download. Although it is much better I still get some inconsistency with my idle and there is some minor pops when I let off the throttle. Does that sound right? Any thoughts?
I am a perfectionist and I know this is going to bug me.
So I want to make it better. I have been reading up on this here on the forum and I have narrowed it down to a Power Commander (PCIII) or getting a Race Tuner (SERT) fromHareley Dealer. What is the best option. What will fix my problem the best. I will never do any other upgrades to the motor. I just want it to run as smooth as possible without the popping.I am leaning towards the Race Tuner.OH yeah I live inCalifornia if that helps..... we have all of the EPA BS. Thanks guys.
RE: Harley Download or ???
Well I just called my local dealer and I found out that they can no longer do the SERT here in California.... man that sucks. Sometimes I hate living in So Cal.
I guess that means it is the PCIII for me. Can I buy this already tuned and ready to go or should I take it and have it installed and put on a Dyno?
From the tech sections https://www.hdforums.com/forumid_247/tt.htm
Tuning EFI bikes https://www.hdforums.com/m_341723/tm.htm
SERT, PC III, TFI or DFO? https://www.hdforums.com/m_228829/tm.htm
I went with SERT. CA bikes run the same emission controls as the HDI bikes so they're pretty lean outta the factory. The DL will have helped a bit... but you seem to have already figured out it's not really a comprehensive fix. PCIII if you don't do further works will prolly suffice, lots of good feedback here for PCIII. SERT will do the same, maybe a slightly better job if you really get into the tuning tables (just because it has more possibilities) but its a few more dollars.
Both are better than the DL. I didn't really want the PCIII module on the bike, so SERT was my choice.
ORIGINAL: mikef
If Ya don't mind spending the money Zipper Thundermax with auto tune is the way to go...lace it up and let it do it's thing...I am already into the PCIII or I would have gone that route...I have to get mine Dyno tuned at the local Indy or HD Stealership at an additional $280 on top of the $300 I paid for the PCIII and the T-max will adjust for changes made to your A/C, exhaust and or climate where the SERT won't orI have to re-map the PCIII..
Good luck
Da Bone
Good luck
Da Bone
