going to 18 rear on deuce... what do i need?
RE: going to 18 rear on deuce... what do i need?
I swapped out the stock 160mm for a 200mm Metz on my 07 Deuce. The 200mm fits with the stock swingarm but i needed to change the belt out for a narrower one (which involved removing the swingarm and taking the primary apart). I'm also running a chromed lower belt guard and the HD part for the 2007 doesn't fit if you go for the 200mm and you'll need to use the 2006 version... i think the dealer who did the install for me also needed to grind a bit of it out to ensure clearance. My rim is an 18 x 5.5 Arlen Ness and a spacer was also required to keep it all centred but i don't have dimensions on the spacer - it will be determined by the rim and hub you run. You'll also need to check clearance under the rear fender. Consider also the requirements of the pulley (width).
Here's the changeover parts needed from HD:
- New belt - 40655-06
- Oil seal inner primary - 12052A
- Gasket primary housing - 34934-06
- Gasket primary cover - 60547-06
- Lubricant (quart) - 99851-05
- 06 lower belt guard - 60316-00A
DeuceRyder
05-19-2008 02:53 PM
