New '08 Fatboy Warranty
I am overseas right now and I orderd an 08 Fatboy for pickup in July when I get home. I also got the extended warrenty on it and I was wondering if it is worth the extra money. I plan on changing out the exhaust and intake immediatly and if its going to void the warranty then whats the point of getting a warranty? Any input?
RE: New '08 Fatboy Warranty
Extended Warranties are a good money-maker for HD. Any slim chance of something going wrong with your ride will happen during your factory warranty period.
I full stage 1 does not automatically void your warranty. If your after market pipes fall off, HD won't cover that. If a 2-pound bug gets past your after market high-flow air cleaner and gets lodged in the intake, HD won't cover that either. In other words, HD must prove that something stock on their product failed BECAUSE of something you did (or altered).
The money you save by not getting the extended warranty will pay for your stage 1.
yea that is a rumor stated that anything you do will void your warranty. I had a wire harness damaged by the oil tank and it was covered. Also the front wheel bearing went bad and i have a Metzler and it was still covered. I was told by my dealer if the engine fails to run just unplug the PCIII and use the ECM and if it still fails it is covered.
ORIGINAL: PoorBoy
I full stage 1 does not automatically void your warranty.If your after market pipes fall off, HD won't cover that.If a 2-pound bug gets past your after market high-flow air cleaner and gets lodged in the intake, HD won't cover that either.In other words, HD must prove that something stock on their product failed BECAUSE of something you did (or altered).
ORIGINAL: Mr. Lucky
[sm=exactly.gif]AKA, the Magnuson-Moss Warranty Act.
ORIGINAL: PoorBoy
I think it was in the last issue of the HOG magazine.
