Riders back rest
Old 04-05-2008, 08:05 PM
ican's Avatar
ican
ican is offline
Default Riders back rest
My wife was looking for a riders backrest that would fit the stock flstc seat, and we couldn't find anyone that made one. So I went out into the shop and made one. I machined areciever that attaches to the seat bolts, and then made a support that is "L" shaped. The lower part of the "L" slides between the riders and passengers seat and locks into the reciever. The reciever stays on, and the backrest is removable. Because the reciever is under the passengers seat, it can't be seen. Two evenings of machining and welding to do what Harley should have made available. Don
Old 04-05-2008, 08:21 PM
WEINERDOGBONE's Avatar
WEINERDOGBONE
WEINERDOGBONE is offline
Default RE: Riders back rest
Let's see a picture! I actually have a Pro Tach backrest that probably would have worked. They look a little goofy though.
Old 04-05-2008, 09:52 PM
Sarge4life's Avatar
Sarge4life
Sarge4life is offline
I'd like to see a picture, too. I'm a great appreciator of ingenuity.
Old 04-05-2008, 10:14 PM
ican's Avatar
ican
ican is offline
I'm still working on the pad, but will post some pictures of the bar and the reciever. It took a while to get all the bend radius and angles figured out. Don
Old 04-06-2008, 12:06 AM
doc_cj's Avatar
doc_cj
doc_cj is offline
I have the Firehouse backrest and like it ... but I'd love to see what you put together. The Firehouse takes about 5 minutes to put on or take off so it's not intollerable, but having something that slips in and out might be nice.
Old 04-06-2008, 07:47 AM
ican's Avatar
ican
ican is offline
Here are some pictures. I hope they send OK Don
[IMG]local://upfiles/24785/5AD50AED6E6D414FB8607C4B15284CCB.jpg[/IMG]
[IMG]local://upfiles/24785/CE35CDD63D7645E48B141F54448ACCC3.jpg[/IMG]
[IMG]local://upfiles/24785/10D5EC660B9D48E48A61F0D882EA8808.jpg[/IMG]
Old 04-06-2008, 09:22 AM
HDRick's Avatar
HDRick
HDRick is offline
Nice job. Looking forward to seeing your pad idea.
Old 04-10-2008, 02:36 PM
ican's Avatar
ican
ican is offline
Finished the backrest. Good news is that it is easy to install and remove. Also, the bracket cannot be seen so when you remove the backrest, everything looks normal. Takes a few seconds to slide the backrest in or out. Installing the bracket is a case of removing the back pad, and installing the reciever under the two front seat nuts. Takes less than 5 minutes. Once it is installed, you can install or remove the backrest in seconds. It took me a while to work out the angles and radius, but I wonder why HD doesn't offera backrest for the stock seat?
Old 04-10-2008, 05:07 PM
fbhawg's Avatar
fbhawg
fbhawg is offline
You should have taken the Firehouse advise.
Old 04-10-2008, 05:35 PM
aviator's Avatar
aviator
aviator is offline
ORIGINAL: fbhawg
why? because, it's better to buy something than to use your own ingenuity and talents?
CSS899
05-12-2017 08:12 PM
Redlegvzv
10-23-2015 09:24 AM
Slim G
01-17-2013 02:03 PM
Pezz
07-12-2009 02:59 PM
dionne51
09-30-2006 09:51 AM
Quick Reply: Riders back rest
