FRONT END CHANGE MAX RAKE/STRETCH
Looking to change out the front end on my 07 Night Train. Was wondering if anyone knows what the max rake/stretch is in order to maintain a good ride both at lo and high speeds. Alsoif anyone can give me an idea how difficult it is to actual do i.e. additional parts required, can I do it myself in the garage, etc...
Thanks for the advice!
RE: FRONT END CHANGE MAX RAKE/STRETCH
What are you planning on changing to. You really can't change the tree rake much or it'll start getting sketchy at speed. The stock trees have rake built into them already, I've hear 2 degrees but that has been a source of debate for some time.
Guys have tried running raked trees, generally 5 degree raked trees, and have had poor success. Many have since removed them.
More tree rake reduces trail, more neck rake increases trail. Longer forks also increase trail by raising the front end of the bike, thus increasing neck rake, same as lowering the rear.
Baron,
looking at getting a black front end from Demon Cycles, black billet tribal that is 6" over stock with 0 degree rake. Will this work without affecting the ride? Will it push the rear down? I've attached a pix and the specs. Is this a major undertaking? I recently changed out the bars so I wanted to get a black front end to match.
BLACK POWDERCOATED
COMPLETE TRIBAL-STYLE FRONT END
+6" OVER STOCK
0° RAKE
Highest quality custom front end. If you want your bike to be the best of the best - this is the one you need.
Uncompromising show look. None better.
39" Overall length.
41mm forks.
Single disc application.
Comes with axle.
Tribal-style black billet triple trees with 0° rake.
Will fit any Harley-Davidson model with 1" stem
and any custom application.
[IMG]local://upfiles/37033/90A03860779C4F218F85A9E53BAE88C4.jpg[/IMG]
BLACK POWDERCOATED
+6" OVER STOCK
0° RAKE
39" Overall length.
41mm forks.
Comes with axle.
That's gonna stick the front end up in the air pretty high and the bike will sit way unlevel and look outta wack IMHO.
You'd be better off just having your trees and lower legs powder coated if you ask me.
Not only that but Demon's quality is questionable at best.
Please look at the "good/bad" shopping experiences in this forum....
https://www.hdforums.com/m_2054638/m...tm.htm#2054638
From reading most of this, I would not try and buy from them.
Baron is 100% correct with the Demons Cycle most of his stuff is extremelly questionable,but try this link and you can check your rake and trail:http://www.rbracing-rsr.com/index.htm when you get to the site go to the tab that says calulations and all it is after that is plugging in your numbers and it will give you the info.
yeah man. Baron has got it right. The only correct way to rake out the bike and not have the ride suffer, you've got to get the frame cut. Have them actually rake the neck. And they must know what they're doing. As for the extra 6 inches. It would jack up the front like crazy and it would be pretty stupid.
Rich Train Driver
16
03-24-2007 04:15 PM
