change syn. oil in the spring?
RE: change syn. oil in the spring?
ORIGINAL: VtBlackDog
I put synthetic oil in my FXST last fall; should I change it after it has sat over the winter like one would dino? Or will synthetic be ok after sitting a few months?
If you changed your oil and parked it for the winter, as one should,you don't have to change it again when you fire it up in the spring. It'll be good until your next scheduled change.Oil does notbreak down just sitting in the bike, it's the heat and friction that puts the boots to its integrity.
as a rule of thumb i change my oil 2 times a yea and i use syn oil. i change in the spring and i change it about 1 or so before u put it away for the winter. and i do not put the syn2 in all the holes. harley says that u can but when i did it the tranny seens to make noise with the syn3 in it. so i use syn3 in the motor and the reg. oil in the primary and trany.
ChopinRockwooD
04-21-2009 08:14 PM
