Springer parts book ?
Don't have a parts book for a FL springer front end ('06) so was wondering if anyone has a pdf. or a book they can scan. I need to look at the riser/isolator bushings with part #s if possible. Put on apes and now need to stiffen up the risers. There should be some aftermarket somewhere out there.....
RE: Springer parts book ?
This is interesting... I'm also having apes installed on my FLSTSCi Springer and neither the vendor nor my mechanic mentioned the need to stiffen the stock risers, just that the bushings need to be replaced with poly. What size apes did you go with? Mine are 13", but if I went taller, I suspect that the stiffening kit would be needed to account for the increased leverage.
-jmc
-jmc
scorchedearthpolicy
09-19-2010 09:56 AM
02Springer
10-03-2009 06:05 PM
