front end on potholes
Old 04-18-2008, 01:56 PM
jefnightrain's Avatar
jefnightrain
jefnightrain is offline
Default front end on potholes
Have an 06 night train that I bought a couple of months ago. When I hit small holes the front end seems to clunk a little, up around the triple tree. This is my first harley & I don't know if this is normal or something needs adjusting. As always thanks for your guys help.
Old 04-18-2008, 01:59 PM
MT's Avatar
MT
MT is offline
Default RE: front end on potholes
No worries my does th esame (2000 FXST) However yesterday I nailed a big one doing 75 on the freeway. Made a good sized dent in my Thunderstar wheel (not even a year old) and it cracked from Valve stem back to the first mag/spoke. Looks like the stock spoke wheel is going back on till I can decide what I'm doing with the front wheel
Old 04-18-2008, 02:00 PM
tombeving's Avatar
tombeving
tombeving is offline
If I had to guess, I'd say your front shocks are bottoming out. I had that happen to me a few times. The roads down here are pretty bad.
Old 04-18-2008, 07:13 PM
HD7585's Avatar
HD7585
HD7585 is offline
Your neck bearings are to lose, Adjust them and grease them [&:]
Old 04-18-2008, 07:58 PM
rbabos's Avatar
rbabos
rbabos is offline
On my fxstc the headlight was bottoming out inside. Had to clearance the bracket to allow the rubber bushings to move freely. May or may not be your case. Just hit the top of the shell with your hand to find out.
Ron
Old 04-20-2008, 09:52 AM
FL DEUCE's Avatar
FL DEUCE
FL DEUCE is offline
If your bike is still under warranty take it in and the HD shop will adjust the bearings free of charge. It happened to my 07 Deuce and that's what I did.
Old 04-20-2008, 11:32 AM
rockerhead's Avatar
rockerhead
rockerhead is offline
+2 on neck bearings
Old 04-20-2008, 12:48 PM
Rhubarb's Avatar
Rhubarb
Rhubarb is offline
+3... tighten that head.
Old 04-20-2008, 01:53 PM
Mr. Lucky's Avatar
Mr. Lucky
Mr. Lucky is offline
Is the usual lithium grease okay to use?
Old 04-20-2008, 02:01 PM
Redd's Avatar
Redd
Redd is offline
ORIGINAL: jefnightrain
I have an 89 FXSTC and it has done that since I got it. The 1st few times it really freaked me out. I had the bearings redone a couple times and checked out the front end top to bottom. 19 years later still the same, and I've never had a problem other than that creepy sound once in a while.
Quick Reply: front end on potholes
