19" vs. 21" front
RE: 19" vs. 21" front
It's all a matter of priorities. All other things being equal, a 19 incher will give you more sidewall. So... a 19" will provide a cushier ride at the expense of somwhat mushier handling;a 21" will provide crisper turn-in at the expense of decreased front brake performance.
I made alot of changes at once on my 07 Street Bob;
1) Wide Glide trees
2) Progressive springs
3) Extra Heavy fork oil
4) 21"x3.5" front rim with 120/70 Metzeler tire
I've noticed a significant improvement in handling and overall "feel". It is a bit stiffer but the improvement in ridability is awesome. As far as braking goes, yes in theory the larger rim would decrease braking performance but I havent really noticed a real difference. I weigh 280 lbs. and havent had an instant were I thought I wasnt going to stop. Just my .02 Not to mention it looks alot better IMHO.
[IMG]local://upfiles/40507/9363C706A6414C9884AAA8195882646C.jpg[/IMG]
1) Wide Glide trees
ORIGINAL: Muddyape
1) Wide Glide trees
1) Wide Glide trees
did you have to change the front fender in order to clear the bigger 21" wheel/tire?
thanks
What do the numbers on the tire mean? eg Metzeler120/70 and MH90-21 54H? (stock tire for softail fxstc 07). 21 is obviously the rim diameter. What does the 120 and MH90 mean and 70 and 54?
I am assuming the 120/70 is fatter than the stock rubber? Will it clear the fender on the fxstc 07.
thanks
thanks
anubisss
05-17-2011 08:19 PM
