new 103 motor is a 110 hp good??
RE: new 103 motor is a 110 hp good??
fuzzy- those numbers sound pretty strong. Post this info in the Engine thread, and see who chimes in. Most guys here who post big numbers are running a good 2 into 1 pipe, such as the D&D Fatcat. This pipe is known for improving a build. Good luck.
Thats actually pretty good for a 103,depending on your pipes. What are you using? I have seen pictures of some vance and hines 2into1 pipes on a rocker, but the configuration is not recommended by the factory. I received a reply about this from a rep as follows.
Larry,
There are people installing the softail configured pipes on the new Rocker but we do not recommend that fitment. Our R&D did the fitment and discovered that the rear cylinder pipe fits to close to the oil tank and the oil lines. The heat coming out of that pipe will eventually cause some damage. Unfortunately for those who have already installed them we will not grant any type of warranty because we did not recommend that fitment. So I strongly suggest that anyone that wants to install V&H pipes on there new Rocker wait until we come out with out redesigned pipes.
Sincerely,
Hector Montoya
Sales/Tech
Vance & Hines Performance
13861 Rosecrans Ave.
Santa Fe Springs, CA 90670
(800) 592-2529 ext. 114
www.vanceandhines.com
So keep that in mind when looking for pipes.That 57mm throttle body must really push the gas! I only used a 50 mm.
Larry,
Sincerely,
Hector Montoya
Sales/Tech
