Cams for Crossbones
Cams for Crossbones
I would like to get cams for my crossbones but I honestly dont have a clue what kind to get and how much they will cost me. I cant afford to spend a whole lot on the bike, but I would like to have the potato sound that is synonomis with Harleys. Ive been told that new cams will get that sound, as well as a little performance. Can anyone recommend a good cam that isnt too expensive but will give me the sound im looking for as well as a little performance?
RE: Cams for Crossbones
Swing over to the Engine/Trans section of the forum...Lots of great info there....
Cams, running in and around the $300.00 mark.. What I don't know is what cams you can move to without other upgrades bore, etc.?? Shop around, you can get a good deal on cams at less $$ for sure.
Alot of imput from the forum for sure. Also, not sure if aftermarket cams,(andrews Cams-which maybe better than SE CAMS, would void your warranty??
Download the Screamin eagle catalog from harleydavidson.com, and they have a listing of all the cams page 58 - 59. And whats compatable.
All I know, it gets expensive to go fast.
I think you may be limited to SE cams due to the warranty.
Also, I don't think your're going to get the potato, potato sound from a EFI TC motor. I have a carced TC88 with hot cams and although it hits a noce lick you can dance to, it doesn't sound like the old pan heads.
Marsh
Marsh
I can't tell you what will work best for you, nor can anyone else. However, I changed my TC88 EFI to SE203 cams. it has a lop at idle, great sound & an improvement across my riding band, low & mid RPMS. As for starving the engine of oil,....I don't think so! Do you thiong EFI bikes had a different oil pump than carbed bikes........... NOT!
