96 ci starter knock
RE: 96 ci starter knock
I think I have the same problem on my stock '08 Heritage.
It's a dull thunking sound - like a loose bearing on a car. Sometimes the starter gets thrown out and it may take 2 or 3 tries to get a start. Happens when the engine is warm; rarely when cold.
Discussed it with my Harley dealer (didn't have the bike there). They don't know what it could be, save to say "Harleys are noisy", but I have appt for later in May.
One auto mechanic and two experienced Harley "wrenches" think it is a timing problem: if I understand correctly, the start timing is too far advanced and the piston does not have enough momentum to get past TDC before being forced back by the combustion. As a result the starter gets whacked.
Tried regular gas - no difference. Others on this forum have reported the problem going away after break-in.
Gary
Gary
ORIGINAL: DocTkd
I have an 07 Softail Custom. It's my understanding that the knock you hear when starting is the compensator, a common and harmless effect. That said mine starts every time no problems like GMul is experincing.
Mine is getting progressively better with break-in. I have just over 2800 miles on mine and it isn't nearly as bad as it was when I first bought it. It only makes sense that a starter on a 96ci motor is going to have to work harder than one on a 88ci. If the stock 96 had compression releases like the 95 (88 big bore kit), it probably wouldn't have the knock-back.
ORIGINAL: Sarge4life
Mine has 2000 miles and may be improving. Recently the engine has, on occasion, been able to turn a full revolution before starting normally. A good sign, I think. I'm keeping my fingers crossed.
"Knock back" - good descriptor for the problem
Gary
ORIGINAL: john lockwood
Has anyone got a solution to the loud knock the starter makes as it engageson the 2007 96 ci and do you know why it makes it?
Thanks John
Thanks John
Ron
JeredShoopman
06-07-2012 02:43 PM
Topspin
01-02-2008 09:49 PM
