Stage 1?
RE: Stage 1?
Close but no cigar, they are add-ons that attach to the O2 sensors that fool the system to add fuel and richen the AF mixture which will cause the bike to perform better and cooler too. Does your bike even have O2 sensors???The IEDs and XiEDs are for '07-08 and later models...I think we need to look to the old owner to see if he did any other adjustments to the AFR, otherwise find a AF fuel module that will improve your performance.
RE: Stage 1?
Sorry coatit, I did not read your note as carefully as I should have. Your bike is "injected", not carbeurated.
If you can get some info from the previous owner(s), that would certainly be a great point to start gathering some vital info on your bike. Given the info you have here, I would say to finish what the previous owner started, i.e., a stage 1. Change the spark plugs, add a free flow filter (K&N), a fuel management system (Fuel Pak, Power Commander, etc.), map it out, and you will likely be in pretty good shape. There are maps on the Power Commander site with the V & H pipes and filter choices that will likely zero your bike in.
The other alternative (adistant one in my opinion)is to put stock exhaust back on and remap the injection system to help manage the heat.
RE: Stage 1?
ORIGINAL: Vikingnomad
Even if you could hook them on somehow the earlyier ECM that never hadO2 sensors probably has no self adjustment capacity anyway. Without the O2's to give it some kind of feedback any self self adjustment capability would bekind of a pointless.
IMHO Your best betwould be to get some kind of add-on fuel management system (PCIII, Fuel Pac, etc.) or get a SERT (but it generally costs more todyno tune) and have the bike dyno tuned. Unless your seriously contemplating some more 'major' internal engine upgrades I would not bother with anything more sophistocated like areplacement ECM (like a Thundermax w/Autotune, Daytona Twin Tech). They cost significantly more and will require you toeither get newer pipes or have yoursfitted with O2 bungs to accomodate the required wideband O2 sensors.
RE: Stage 1?
sounds like its running lean. find out if you have a stage one installed it should have been done with the exhaust if you do then you will need a pc111 or fuel pack or harley race tuner to get it right. you will need a device that will let you over ride the on board ecm. this will help them if you want to spend more you can have it put on the dyno for a near perfect map.
