AFR
RE: AFR
yeah it has autotune. the thing is that i'm waiting for a response from them. I don't have the orig. receipt or packaging. the thing is just sitting in my garage. i've been riding with the stock ecm,but am afraid to cause engine damage. I just can't control myself, so i need a good quick fix.[&:]
RE: AFR
I asked them for a little help with mine and they got back to me withintwo days, and I accidentally screwed up my own e-mail address. The guy couldn't get me that way so he called on the phone.
What mods have you done to the engine? I'll look through themaps I have and see if I can figure it out for you.
EDIT;
If you only have the Matin Bros exhaust and Zippers A/C you could use map #391 as a start then adjust it to run at 13.8 to 1 or slightly richer. The Autotune should be able to handle the fine tuning in a relatively short time frame.
EDIT;
RE: AFR
I can give you a quick safe fix for about 99 cents.Unplug the 02 sensors and replace them with a 330ohm 1/2 watt resistor. That will fool the computer into thinking you are open loop and run the engine at a rich 12.1 afr. I ran mine like that for 4 months and even went on a trip to the mountains. Will also run very cool too.
RE: AFR
Thanks, but I already dropped it off at Harley for a SERT. Theysaid they will put it at about 13.3:1 forthe altitude. I still plan on sending back the T-max for a repair/replacement then probably gonna sell it on E-bay. Don't know yet. I'll see within the next few weeks (when I get off my lazy ***).
RE: AFR
ORIGINAL: mori55
Load the smarlink on your pc and read the Manuel and pick what map is close. How hard is that? Why is it sitting in your garage? What are you waiting for ? READ THE MANUEL . Very easy install.
