Fork Brace
RE: Fork Brace
I'm torn about a brace. I've used them on Triumphs and Hondas, but not the HD. What specifically do you notice in the way of improvement? What I'm fighting now is a high speed "oscillation", for lack of a better word, in the corners. Already have Progressive front and rear. Thanks. Frank
RE: Fork Brace
ORIGINAL: twiceretired
Most of the wobble in a front end is caused primarily by slop in the overall suspension (fork tube) system. If there is any slop its going to wobble, its inevetable. Thefork brace helpsadd some rigidity by locking the lower legs in a box structure with the axle. Locking the lower fork legsprevents them from rotating in different directions and that will significentlyreduce the wobbles.
Nothing however is perfect and because there is always someslop in the way the upper and lower fork tubes fit together you will get some wobble from that. Unfortunatly its something thatonly gets worse as time and wear take their toll on it.
Frank too
RE: Fork Brace
Fork braces do a great job stiffening up your front end. They help on hard turns, rough roads, and especially on bikes with single rotor front brakes. To see how much it tightens the front end, without the brace on, stand in front of the bike and hold the front tire firmly between your knees while trying to turn the handlebars. You will see your front fender flex and back and forth dramatically from where the fork tubes are trying to go in different directions. Put the brace on and try it again. The fender won't hardly move at all.
Received 1,211 Likes
RE: Fork Brace
ORIGINAL: WAhog
Would a brace be of any use on a Fatboy or are the forks too beefy already (note it only has a single rotor brake setup)?
