Rockers w/ V&H BR 2into1 Reply
You Rockers with Vance & Hines Big Radius 2 into 1 I need a little help. I have decided to go with it on my Rocker and now that V&H pushed back the Rocker specific again till Aug-Oct, I'm going with the standard system. Gib(RM69) said the bracket that comes with the 2x1 will work with some bending, any info you could provide would be much appreciated. Can some of you take some close-up picsof the gap between the rear exhaust and the oil tank and the clearance between the exhaust and the oil lines ?
Rockers with the 2x1 and SE Heavy Breather, what did you do for reprograming, if anything at all ? SERT, PCIII,Fuel Pack ?
RE: Rockers w/ V&H BR 2into1 Reply
I've got the BR2-1 and heavy breather on mine... My dealer had a program to re-map it and so far it's worked well.. No lag or dead spots and plenty of acceleration..
As for the 2-1 fitting or needing bending, I installed mine and it went right one after you remove all the factory mounting stuff.. Plenty of room between the tank and the rear header.. No heat issues to this point.. On a side note I would recommend getting the V&H peg kit 16927 (I think that's the number) when you order the pipes.. The pipes come with one of those kits to relocate (raise) the right side passenger peg but you ahve to order the additional kit ($19) so both pegs are the same height..
