2007 fatboy swingarm to use on 2005 fatboy
Old 06-16-2008, 09:44 PM
fatboy48's Avatar
fatboy48
fatboy48 is offline
Default 2007 fatboy swingarm to use on 2005 fatboy
Has anyone tried or checked to see if the new 2007 and 2008 fatboy swingarms can be mounted to a 2005 fatboy. I am going for the 200 rear tire on my 2005. I have been told by a few people that I can use the 2007 or 2008 fatboy swingarm to make room for the bigger tie. I would also have to cut the rear fender horns off the 2005 and get aftermarket fender and struts.
Old 06-23-2008, 01:00 AM
jumporjerkoff's Avatar
jumporjerkoff
jumporjerkoff is offline
Default RE: 2007 fatboy swingarm to use on 2005 fatboy
I asked that very question to a harley tech, he said that the frame is different and it would not work, i was hoping to sell my 200 swingarm
to somebody with a 2005 fatty, shame
Old 06-23-2008, 04:49 AM
Scott.Harris's Avatar
Scott.Harris
Scott.Harris is offline
6th Gear
Not only that, but the front to rear wheel center alignment would be off. My advise, don't attempt.
Old 06-23-2008, 05:13 AM
Velocity1's Avatar
Velocity1
Velocity1 is offline
FWIW... It's possible to fit a 200mm tire to even an '02 swingarm.&nbsp\\; Dimensionally, they're identical to the '07's.&nbsp\\; I built my own kit using HD parts, ('07 Bobtail fender and all the original belt guards etc.)&nbsp\\; I centered the wheel up in the swingarm and adjusted everything else to fit from there.&nbsp\\; Over 3k trouble free miles.&nbsp\\; I did use Custom Struts.com and removed the frame horns.&nbsp\\; The struts adapt the '02 frame to the newer wider fender,&nbsp\\;(bolt pattern is different where the struts bolt to the frame),&nbsp\\;and removing the frame horns provide the clearance needed for the tire.&nbsp\\;
&nbsp\\;
Pretty straight forward mod these days.&nbsp\\; And yes, it's pretty but it ain't cheap even if you do it yourself.
&nbsp\\;
Mine is an '02 Softail.&nbsp\\; Search the subject.&nbsp\\; I'm sure you'll find quite a bit of information relative to fitment, involving struts, wider fender and wider wheel, etc....
&nbsp\\;
Good luck with it !
&nbsp\\;
V1
[IMG]local://upfiles/20625/737DD68633FC4A639D42570F66507152.jpg[/IMG]
samsneeze33
10-29-2017 07:03 PM
IceMan58
08-20-2012 11:19 PM
harleynt
01-12-2009 10:58 AM
deezel11
07-30-2008 04:53 PM
black and blue
05-08-2008 07:59 PM
Quick Reply: 2007 fatboy swingarm to use on 2005 fatboy
