Rear brake light switch
RE: Rear brake light switch
I also have an '-5 Fatty.
About 3 weeks ago I noticed that my brake light was not working. Thinking I would also have to buy a new sending unit, I checked the connections with a multi meter and found that the switch was fine. I checked the bulb and found that the pins in the light socket had corroded to the point that it was not getting a connection. A small screwdriver was all I needed to bend the pins back out to make a good connection. All is well now. \\; Let me know if this works for you.
Good luck.
Good luck.
No change of grips. The front switch works just fine.
Took another look at it and checked the travel. Just put on new rear  \\;pads.
Gave it a hard whack on the pedal, heard a pop and it all works fine.
Something must have been stuck. If it dont go, FORCE IT.
JK, not my normal mode of repair, but in this instance it seemed to work.
MikeM
MikeM
bfgoodmudder
01-31-2010 09:39 AM
eblansfield
06-11-2008 12:58 PM
