Rear brake dragging
RE: Rear brake dragging
Apparently I have a brake dust thing going on. I cleaned the caliper and pads with brake cleaner today and it appears to have stopped squealing. A quick spray seems to have done wonders.
Now if I can figure out whats up with the rear brake light switch I will be all set.
MikeM
MikeM
The squeel is probably from the caliper hitting the back of the brake pad. When new pads are installed you need to grease the metal side of the pad that contacts the metal calipers. Then put a small film of grease on the two pins that hold the pads in place. That will stop the squeeks.
martinfxdx
07-13-2008 07:52 AM
