Rocker Throttle/Idle Adustments (need help)
06-18-2008, 06:57 AM
Just installed HD drag bars on my rocker, and I have to adjust my throttle and Idle cables. \\;I have too much play. Please help with any suggestions/advice.
06-18-2008, 07:55 AM
RE: Rocker Throttle/Idle Adustments (need help)
The only adjusting you can do is the play in the throttle itself. Do you have your owners manual. The adjustment is under the rubber boots on the cables.
jim
06-18-2008, 08:26 AM
hd specifically says you have to get shorter cables when you put their drag bars on the rocker. did you get the shorter cables? if not, good luck.
also, you can rotate the stock bars enough to make them feel like drag bars.
reds2harleys
06-07-2010 07:14 PM
Jaxx
04-13-2010 10:53 AM
Alain
Softail Parts
04-01-2010 02:11 PM
BLK08ROCKERC
03-29-2010 01:30 PM
sledhead140
05-04-2009 12:12 PM
