PCIII or PCIII EX
PCIII or PCIII EX
I have been doing some research on ECM controllers for my fatty. \\; I am leaning on the PCIII, but there is also another version (PCIII EX) \\;that utilizes the O2 sensors, or CA friendly. \\; One of my concerns \\;is riding at different elevations. \\; How does the EFI adjust the AFR without O2 sensor feedback using the PCIII? \\; Does the EX version allow the O2 sensors to operate in a more wide band mode. \\; I want to be sure \\;mine is \\;running optimal \\;when I \\;head into the mountains. \\; Road trips here in AZ can vary \\;over 7000ft \\;
RE: PCIII or PCIII EX
I think you need to ask power commander how it works. The PC 3 that does not use the 02 sensors if like tuning on a carb model. you can use a canned map or get a dyno tune for perfection. if you want the best of both then get a thunder max with auto tune. Just set it for 14.7 when getting your inspection and reload for 13.5-13.8 when done.
I went from sea level to 5000 ft and it was fine. You can always change the map 5% to offset if going over 5000 ft and then change it back. The Thundermax re-tunes it self and it requires no dyno tune. I am keeping my PC 3 because i dont plan on changing the pipes.
