Heritage classic/Stiffening rear suspension
RE: Heritage classic/Stiffening rear suspension
I bought my spanner from the dealership for around $7.
The hardest part in adjusting the shocks, is the first time you break the retention nuts loose. They come with loctite on them, so you might have to use a heat gun on them first.
It takes a spanner wrench to turn the shock body after you brake the retention nuts loose and back them off. I use a 1-1/16" open end wrench, that I cut down to 6" long. Not much room under the bike. The further you extend the shocks the firmer they get. Paint a white stripe on the body of each shock, when they are in the \\;full open or closed position. Use the stripe to count how many turns you give each shock, to keep them even. They will turn a little over 4 complete turns. I adjust mine while om the jiffy stand.
Tom
Tom
Thanks guys.
The wife and I are heading out on a \\;long trip. So I thought I needed to tighten it up a bit. Given the extra weight of luggage etc.
I loaded it up and did a pre-ride with everything and actually found the suspension to be a bit softer and it seemed to be more confortable the way it is.
Other than the rear sitting a bit lower it seems fine the way it is. No tire rub etc.
ORIGINAL: tmitchellof PG
I just bought a spanner from the local stealer for $10.95... $30 is really steep!
Thanks for the thread... I've been meaning to make the adjustment, so I'm going to adjust mine this afternoon.
Roger
