Shake at 65 kph (40mph) 2008 Fatboy
Hi all
When i accelerate and go through 65 km (40mph) I get a shake in the handlebars front end \\;same when I am decelerating down through 65 km. it seems to be just at that speed.
Is this normal? The dealer said yes but I don’t think so. I rented a lot of Harleys and rode friend’s \\;bikes and they do not do it.
Mine is a 2008 Fatboy with 500 KM on it. This is bothering me some...
Thanks
Liam
Thanks
Liam
RE: Shake at 65 kph (40mph) 2008 Fatboy
I had a wobble at higher speed. When we checked the bike (08 Fatboy) we found the stearing head was loose, the rear wheel slightly out of alignment (and too tight), and the front forks we slightly misaligned - all from the factory!! Get an experience independent to check it cause I have no wobble at all at 65kmh.
As an aside I still have a slight wobble at 110-120kmh but I have started to put this down to me hanging on too tight to the Burleigh Western bars (which are very wide) when the wind is buffeting me.
I have the same wobble, and at the same speed on my '08 Fatboy. \\; Two different indy's haven't found it yet, one of them thinks it is some kind of torque harmonic going through the whole frame. \\; All their checks have been to spec, and I am on a fresh set of tires with nothing worse or better. \\; The steering head has been messed-with a couple of times (both in and out of spec) and nothing is changing my very solid symptoms.
I have simply accepted this as part of my FB personality (I think each bike has its quirks). \\; The shake goes away quickly, so I am not really going to worry about it.
