Passenger Seat Bolt/Screw
RE: Passenger Seat Bolt/Screw
ORIGINAL: HDRick
Do you just mean the screw socket in the fender?
No, \\; I know that part stays in the fender. \\; It's the screw that's in the bracket (which is still attached to the passenger seat) which goes into the socket in the fender. \\; I figured I could use the same screw to use on the fender bib.
You can get the whole screw socket out of the hole in the fender and move it back if you need to.
Thrre is a plastic clip ring around the screw socket, just pop it off and turn the screw socket till \\; the key gets to the slot, It should drop out, then usr the black cap to fill hole, then u can use it in any of the holes back there for a diffrent seat, I did this on my 07 FB when I put a new seat on. I hope this helps, and the bracket that hold the 2 screws in the fender pops right out
Well I just got back from the stealership (boy, do they ever deserve that name !!) and a replacement screw is $20.00 plus tax ( Canada ). \\; All I want is to put the bloody fender bib on !!! \\; They sold me this black plastic cap ( $4.00 for that ! ) that they said would work...........it doesn't !!!
