Changing rear brake lever WTF!
Old 06-29-2008, 08:13 PM
BoneCrusher's Avatar
BoneCrusher
BoneCrusher is offline
Default Changing rear brake lever WTF!
OK seriously what have you guys had to do to get that F'n clevis pin outta the rear brake lever to change it out?&nbsp\\; I tried everything, prying it from behind, WD-40, loosening the mounting screw to give me some wiggle room, etc.&nbsp\\; Of all the things I've ever done to my bikes this is the dumbest thing I've had give me this much trouble lol.&nbsp\\; This **** isn't budging.
Old 06-29-2008, 10:26 PM
WARG's Avatar
WARG
WARG is offline
Default RE: Changing rear brake lever WTF!
Did mine a year or two ago, it was&nbsp\\;a headache, but it did come eventually.&nbsp\\; I can't offer any secret trick, just patience.
Old 06-29-2008, 10:59 PM
kbflash44's Avatar
kbflash44
kbflash44 is offline
I might be wrong but I think there's a c-clip you have to remove first.
Old 06-29-2008, 11:08 PM
BTL's Avatar
BTL
BTL is offline
Mine was a pain to take out, but worse to put back in, when I changed over to the billet aluiminum arm.
Old 06-30-2008, 10:54 AM
BoneCrusher
Thanks guys.&nbsp\\; You are right kb there is a small cotter pin that you have to take out first.
&nbsp\\;
BTL that is my other biggest fear, once I get this thing outta there it would be just as hard or harder to get back in then I'll really be pissed lol.
Old 06-30-2008, 11:44 AM
brianp25's Avatar
brianp25
brianp25 is offline
seems like mine came with a new one, so i just cut the old one. and it is a pain to get back in. i think i&nbsp\\; turned the pin facing down and used needle nose pliers to push it up.....been a while
Old 06-30-2008, 12:05 PM
aviscomi's Avatar
aviscomi
aviscomi is offline
Just changed my rear lever 2 days ago and I had the same issue. The solutions was Pliers, place the front portion of the pliers on the flat surface of the existing lever the rear portion of the pliers should be on the pin. Then just squeeze and it'll come right out...hopefully.
Old 06-30-2008, 03:29 PM
ffontaine's Avatar
ffontaine
ffontaine is offline
I just did mine, here's the solution.&nbsp\\; after you take the cotter pin out, place a socket (~7/16 to 1/2") over the clevis pin, bolt side over the head of the clevis pin.&nbsp\\; Then take a set of channel locks and place one end on the back side of the clevis pin and the other on the wrench end of the empty socket.&nbsp\\; Then squeeze hard &amp\\; the pin will pop out into the socket.&nbsp\\; At that point it may not be all the way out but it will be out enough to grab &amp\\; easily pull out with pliers.&nbsp\\; Trust me, works like a charm.&nbsp\\; The good news is getting it back in is a lot easier.
&nbsp\\;
Good luck,
&nbsp\\;
Fred
&nbsp\\;
Old 06-30-2008, 04:55 PM
BoneCrusher
Thanks avis and ff, that sounds like it would work you guys both did it similarly.&nbsp\\; ff I like the socket trick nice idea.
Old 07-02-2008, 06:58 PM
NT_rider06's Avatar
NT_rider06
NT_rider06 is offline
I just replaced both levers on my bike. used snapring pliers.&nbsp\\; just insert the snapring pliers in the small holes on the clip. set thumb of other hand on bottom of pin, sqeeze pliers slightly. push up on pin with your thumb. pin slides up and clip stays under your thumb. took literally 15 seconds.
Quick Reply: Changing rear brake lever WTF!
