10" Mini Apes on Fatboy - Stock Cabling and Wiring Harness?
RE: 10"\\; Mini Apes on Fatboy - Stock Cabling and Wiring Harness?
I had to add wire to mine. 10' ran wires internally. Spliced the wires staggered so it would slide though the bars. I would need to check back to the length of the brake, throttle and clutch cables. I had to change everything. I would have to check on specfic lengths of each. I measured with a piece of string running from point a to b then measuring length. Kent
RE: 10"\\\\\\; Mini Apes on Fatboy - Stock Cabling and Wiring Harness?
Although I did this on a Softail Standard.
I put the 8 inch mini apes from the wide glide using the wide glide risers (1" if I recall) on an 07 standard and was able to use the stock wiring and cables. But it was JUST right. I am not sure you can get by with it on a 10 inch ape. I could be wrong but I don't think it will work.
ChadWeasel
09-26-2009 08:52 AM
