New Bars...
RE: New Bars...
Good deal. Who did you get them from? Its not to hard. Use a service manual if you have one. Just do it one side at a time. Take it off then put it right on the other bars so you dont forget where and how it went. The switch housings can be tricky. there are some tiny screws and brackets in there that like to move. If you are internally wiring he bars and havent done it before I have a awesome trick that will have it done in 1 min per side.
RE: New Bars...
It can be done. Is there an opening at the bottom of the bars for wires? If not you will have to cut one and one on each side of the bars bye the switch housings. The wires should be long enough. Look under the tank the exsess is usually under there zip tied. If not you can get wire and solder it to the stock ones and recover them with the heat wrap.
RE: New Bars...
Should look like this. These are wild one chubbys. You can cut them out with a dremel. Or just drill them out. Then smooth the holes with the dremel.
[IMG]local://upfiles/56156/928002877F2D4B209D88764FC19EEEF9.jpg[/IMG]
[IMG]local://upfiles/56156/6145655FD01D49B5A726E106953EDAE1.jpg[/IMG]
