exhaust pop
RE: exhaust pop
you didn't mention if you got a tune(SE race tuner, Fuel Pak, Power commander III, etc). \\;\\\\\\;\\\\\\\\\\\\\\; absolutely required when you do a stage I and exhaust replacement.
just a side note. \\;\\\\\\; I went with the PCIII over the SE race tuner since the PCIII has MANY more canned tunes available online than the SE tuner does. \\;\\\\\\; They found my exact exhaust, Big Bore 103, piston size, cylinder heads, etc. in a tune that had already been done, online, so I didn't have to pay for several hours of tuning time to tweak my setup..
the popping is definitely NOT normal. \\;\\\\\\;\\\\\\\\\\\\\\; got my BR 2-into-1 installed a couple of days ago along with a power commander III....just sweet V-twin music in my right ear....
RE: exhaust pop
Actually popping is pretty common. If you have a PCIII just adjust the \\;0 position throttle setting. I added 20 to mine and a little bit to the 2 position and it runs great now with rarely ever a pop. Some people have to put negative numbers like -20 in the 0 position. Just play around with the 0 position which is the closed throttle settings and see if it helps with the popping. You won't hurt anything and if you aren't satisfied then just put all the numbers back to what they were. It's very simple.
RE: exhaust pop
The engines already run lean just being stock, changing the air filter adds even more air and makes it run even leaner. If you have changed the air filter to a high flow one then you definately need to do domething to change the fuel mixture be \\;\\\\\\; it a Fuelpak, PC III or Sert.
RE: exhaust pop
For stage I and stock pipes you need at least the Stage I download. \\; You change the pipes, and you need a tuner (ala PCIII or Sert) or it will pop like hell because of the increased air flow. \\; I started with a PCIII but went to SERT with the 103 build. \\; Both work very well, SERT doesn't require an additional device to be installed. \\;
RE: exhaust pop
ORIGINAL: PigInaBlanket
Actually popping is pretty common. If you have a PCIII just adjust the \\;\\\\\\;0 position throttle setting. I added 20 to mine and a little bit to the 2 position and it runs great now with rarely ever a pop. Some people have to put negative numbers like -20 in the 0 position. Just play around with the 0 position which is the closed throttle settings and see if it helps with the popping. You won't hurt anything and if you aren't satisfied then just put all the numbers back to what they were. It's very simple.
